Day 22 is about moving around on a map. The part 2 twist maps the map onto the edges of a cube.
I started with a class to handle the map called MonkeyGrove. The only tricky part was handling the “weird” wrapping rules. The parsing apart the movement instructions is also slightly tricky, but just takes a very simple state machine.
final class MonkeyGrove
private final int width;
private final int height;
private char[][] map;
private Coordinates playerCoordinates;
private int playerFacingDirection;
public MonkeyGrove(final int width, final int height)
this.width = width;
this.height = height;
map = new char[width][height];
playerCoordinates = Coordinates.INVALID_COORDINATES;
public void applyMap(final String[] mapData)
clearMap();
for (int y=0; y<mapData.length; y++)
for (int x=0; x<mapData[y].length(); x++)
final char c = mapData[y].charAt(x);
switch(c)
case ' ': break;
case '.':
map[x][y] = c;
if (playerCoordinates == Coordinates.INVALID_COORDINATES)
playerCoordinates = new Coordinates(x,y);
break;
case '#':
map[x][y] = c;
break;
default: throw new IllegalStateException("Invalid input map char: " + c);
private void clearMap()
for (int y=0; y<height; y++)
for (int x=0; x<width; x++)
map[x][y] = ' ';
public void applyMovements(final String movementInstructions)
boolean doneMoving = false;
int index = 0;
String digits = "";
while (!doneMoving)
if (index >= movementInstructions.length())
doneMoving = true;
final char c;
if (doneMoving)
c = ' ';
else
c = movementInstructions.charAt(index);
switch (c)
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
digits = digits + c;
break;
case 'L':
move(Integer.parseInt(digits));
digits="";
playerFacingDirection = playerFacingDirection - 1;
if (playerFacingDirection < 0) playerFacingDirection = 3;
break;
case 'R':
digits="";
playerFacingDirection = playerFacingDirection + 1;
if (playerFacingDirection > 3) playerFacingDirection = 0;
break;
case ' ':
if (!digits.isEmpty())
digits="";
break;
default: throw new IllegalStateException("Got invalid movement char: " + c);
index++;
private void move(final int numberToMove)
for (int i=0; i<numberToMove; i++)
if (!moveToNextSpace()) break;
private boolean moveToNextSpace()
final Coordinates oldCoordinates = playerCoordinates.clone();
switch (playerFacingDirection)
case 0: playerCoordinates = getNextValidCoordinates(1,0); break;
case 1: playerCoordinates = getNextValidCoordinates(0,1); break;
case 2: playerCoordinates = getNextValidCoordinates(-1,0); break;
case 3: playerCoordinates = getNextValidCoordinates(0,-1); break;
default: throw new IllegalStateException("Player is facing in an invalid direction");
int x = playerCoordinates.getX();
int y = playerCoordinates.getY();
if (map[x][y] != '.') throw new IllegalStateException("Player ended on an invalid square" + playerCoordinates);
if (oldCoordinates.equals(playerCoordinates)) return false;
return true;
private Coordinates getNextValidCoordinates(final int xDelta, final int yDelta)
Coordinates newCoordinates = playerCoordinates.clone();
Coordinates prevCoordinates = newCoordinates.clone();
while (true)
newCoordinates.add(xDelta, yDelta);
int x = newCoordinates.getX();
int y = newCoordinates.getY();
if (x >= width) newCoordinates = new Coordinates(0, y);
if (x < 0) newCoordinates = new Coordinates(width-1, y);
if (y >= height) newCoordinates = new Coordinates(x, 0);
if (y < 0) newCoordinates = new Coordinates(x, height-1);
if (map[x][y] == '#') return prevCoordinates;
if (map[x][y] == '.') return newCoordinates;
public long getPart1Answer()
return (1000 * (playerCoordinates.getY()+1)) + (4 * (playerCoordinates.getX()+1)) + playerFacingDirection;
The driver is pretty obvious:
final class Day22
public static long part1(final String[] day22InputLines, final String movementInstructions, final int width, final int height)
final MonkeyGrove mg = new MonkeyGrove(width, height);
mg.applyMap(day22InputLines);
mg.applyMovements(movementInstructions);
return mg.getPart1Answer();
For part 2, things get kinda challenging. You need to figure a way to implement the movement changes of the cube wrapping. I copied my MonkeyGrove to MonkeyGrove2 to make the necessary changes, and created a helper class CubeMovementRules.
The input to CubeMovementRules is a description of the flat sides of the cube like so:
A
BCD
EF
and a set of rules explaining how sides connect to sides, based on each side having letters as above and numbers like:
| 3 |
|2 A 0|
| 1 |
A0F0
A1D3
A2C3
A3B3
B0C2
B1E1
B2F1
B3A3
C0D2
C1E2
C2B0
C3A2
D0F3
D1E3
D2C0
D3A1
E0F2
E1B1
E2C1
E3D1
F0A0
F1B2
F2E0
F3D0
final class CubeMovementRules
public static final CubeMovementRules INVALID_CUBE_MOVEMENT_RULES = new CubeMovementRules();
record CoordinatesWithDirection(Coordinates coordinates, int direction) {};
private int width;
private Map<String, String> translationRules = new HashMap<>();
private Map<CoordinatesWithDirection, String> sideDeterminer = new HashMap<>();
private Map<String, Coordinates[]> sideCoordinates = new HashMap<>();
private CubeMovementRules() // for INVALID_CUBE_MOVEMENT_RULES
width = -1;
public CubeMovementRules(final int width)
this.width = width;
public void defineFlatLayout(final String[] flatLayout)
for(int y=0; y<flatLayout.length; y++)
for (int x=0; x<flatLayout[y].length(); x++)
final char cubeSideLetter = flatLayout[y].charAt(x);
if (cubeSideLetter == ' ') continue;
mapSidesToCoordinates(cubeSideLetter, x, y);
private void mapSidesToCoordinates(final char cubeSideLetter, final int flatX, final int flatY)
final Coordinates[] eitherEndOfSide = new Coordinates[2];
int x1=flatX*width;
int x2=x1+width-1;
int y1=flatY*width;
int y2=y1+width-1;
for (int y=y1; y<=y2; y++)
final CoordinatesWithDirection coord = new CoordinatesWithDirection(new Coordinates(x2,y), 0);
sideDeterminer.put(coord, cubeSideLetter+"0");
eitherEndOfSide[0] = new Coordinates(x2,y1);
eitherEndOfSide[1] = new Coordinates(x2,y2);
sideCoordinates.put(cubeSideLetter+"0", eitherEndOfSide.clone());
for (int x=x1; x<=x2; x++)
final CoordinatesWithDirection coord = new CoordinatesWithDirection(new Coordinates(x,y2), 1);
sideDeterminer.put(coord, cubeSideLetter+"1");
eitherEndOfSide[0] = new Coordinates(x1,y2);
sideCoordinates.put(cubeSideLetter+"1", eitherEndOfSide.clone());
final CoordinatesWithDirection coord = new CoordinatesWithDirection(new Coordinates(x1,y), 2);
sideDeterminer.put(coord, cubeSideLetter+"2");
eitherEndOfSide[0] = new Coordinates(x1,y1);
eitherEndOfSide[1] = new Coordinates(x1,y2);
sideCoordinates.put(cubeSideLetter+"2", eitherEndOfSide.clone());
final CoordinatesWithDirection coord = new CoordinatesWithDirection(new Coordinates(x,y1), 3);
sideDeterminer.put(coord, cubeSideLetter+"3");
eitherEndOfSide[1] = new Coordinates(x2,y1);
sideCoordinates.put(cubeSideLetter+"3", eitherEndOfSide.clone());
public void addRules(final String[] traslationRules)
for (final String rule: traslationRules)
final String part1 = rule.substring(0,2);
final String part2 = rule.substring(2);
translationRules.put(part1, part2);
public boolean doesDirectionOutOfCoordinatesRequireTranslation(final Coordinates coordinatesToCheck, final int direction)
final CoordinatesWithDirection coord = new CoordinatesWithDirection(coordinatesToCheck, direction);
if (sideDeterminer.containsKey(coord))
return true;
return false;
public final CoordinatesWithDirection getTranslatedCoordinates(final Coordinates coordinatesToTranslate, final int direction)
final CoordinatesWithDirection coord = new CoordinatesWithDirection(coordinatesToTranslate, direction);
if (!sideDeterminer.containsKey(coord))
throw new IllegalStateException("Coordinates not in translation list: " + coord);
final String sideNumStr = sideDeterminer.get(coord);
final String newSideNumStr = translationRules.get(sideNumStr);
final int dir1 = sideNumStr.charAt(1)-'0';
final int dir2 = newSideNumStr.charAt(1)-'0';
final Coordinates[] coordinates = sideCoordinates.get(sideNumStr);
if ((dir1 == 0) && (dir2 == 0))
// right side to right side, y->invert y
final int y = coordinatesToTranslate.getY() - coordinates[0].getY();
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, width-y-1), turn180(direction));
if ((dir1 == 0) && (dir2 == 1))
// right side to bot side, y->x
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, y), turnBack90(direction));
if ((dir1 == 0) && (dir2 == 2))
// right side to left side, y->y no translation
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, y), direction);
if ((dir1 == 0) && (dir2 == 3))
// right side to top y-> inverted x
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, width-y-1), turnForward90(direction));
if ((dir1 == 1) && (dir2 == 0))
// bot to right side, x->y
final int x = coordinatesToTranslate.getX() - coordinates[0].getX();
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, x), turnForward90(direction));
if ((dir1 == 1) && (dir2 == 1))
// bottom to bottom, invert x, 180 rotation
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, width-x-1), turn180(direction));
// NOTE ((dir1 == 1) && (dir2 == 2)) not covered
if ((dir1 == 1) && (dir2 == 3))
// bottom to top, x->x no translation
return new CoordinatesWithDirection(getCoordinatesOfCubeSide(newSideNumStr, x), direction);
if ((dir1 == 2) && (dir2 == 0))
// left side to right side, y->y no translation
if ((dir1 == 2) && (dir2 == 1))
// left side to bottom, y->inverted x
if ((dir1 == 2) && (dir2 == 2))
// left side to left side, y->inverted y
if ((dir1 == 2) && (dir2 == 3))
// left side to top, y->x
// NOTE ((dir1 == 3) && (dir2 == 0)) not covered
if ((dir1 == 3) && (dir2 == 1))
// top to bot side, x->x
if ((dir1 == 3) && (dir2 == 2))
// top to left side, x->y
if ((dir1 == 3) && (dir2 == 3))
// top to top, 180 rotation, inverted y
// Left here in case should there be a case that was missed
// (used many times during development)
System.out.println(dir1);
System.out.println(dir2);
System.out.println(sideNumStr);
System.out.println(newSideNumStr);
throw new IllegalStateException();
private int turnBack90(final int direction)
int dir = direction - 1;
if (dir < 0) dir = 3;
return dir;
private int turnForward90(final int direction)
int dir = direction + 1;
if (dir > 3) dir = 0;
return dir;
private int turn180(final int direction)
final int dir = turnForward90(direction);
return turnForward90(dir);
private Coordinates getCoordinatesOfCubeSide(final String sideNumStr, final int offsetVal)
switch (sideNumStr.charAt(1)-'0')
case 0: return new Coordinates(coordinates[0].getX(), coordinates[0].getY()+offsetVal);
case 1: return new Coordinates(coordinates[0].getX()+offsetVal, coordinates[0].getY());
case 2: return new Coordinates(coordinates[0].getX(), coordinates[0].getY()+offsetVal);
case 3: return new Coordinates(coordinates[0].getX()+offsetVal, coordinates[0].getY());
default: throw new IllegalStateException();
And the updated MonkeyGrove2:
final class MonkeyGrove2
final CubeMovementRules cubeMovementRules;
public MonkeyGrove2(final int width, final int height, final CubeMovementRules cubeMovementRules)
this.width = width;
this.cubeMovementRules = cubeMovementRules;
clearMap();
switch(c)
case ' ': break;
case '.':
map[x][y] = c;
break;
case '#':
map[x][y] = c;
break;
map[x][y] = ' ';
int index = 0;
String digits = "";
//dumpWithPlayer();
while (!doneMoving)
doneMoving = true;
final char c;
if (doneMoving)
c = ' ';
else
switch (c)
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
break;
case 'L':
//dumpWithPlayer();
digits="";
//dumpWithPlayer();
break;
case 'R':
//dumpWithPlayer();
digits="";
//dumpWithPlayer();
break;
case ' ':
digits="";
//dumpWithPlayer();
break;
index++;
// System.out.println("move " + numberToMove);
final CoordinatesWithDirection cwd = getNextValidCoordinates(playerFacingDirection);
playerCoordinates = cwd.coordinates();
playerFacingDirection = cwd.direction();
return true;
private CoordinatesWithDirection getNextValidCoordinates(final int direction)
int curDir = direction;
int prevDir = direction;
int xDelta = 0;
int yDelta = 0;
switch (direction)
case 0: xDelta = 1; yDelta = 0; break;
case 1: xDelta = 0; yDelta = 1; break;
case 2: xDelta = -1; yDelta = 0; break;
case 3: xDelta = 0; yDelta = -1; break;
default: throw new IllegalStateException("Invalid direction=" + direction);
while (true)
if (cubeMovementRules.doesDirectionOutOfCoordinatesRequireTranslation(newCoordinates, curDir))
final CoordinatesWithDirection cwd = cubeMovementRules.getTranslatedCoordinates(newCoordinates, curDir);
newCoordinates = cwd.coordinates();
curDir = cwd.direction();
else
if (map[x][y] == '#') return new CoordinatesWithDirection(prevCoordinates, prevDir);
if (map[x][y] == '.') return new CoordinatesWithDirection(newCoordinates, curDir);
public long getPart2Answer()
void dumpWithPlayer()
System.out.println("====");
char c= map[x][y];
if ((playerCoordinates.getX() == x) && (playerCoordinates.getY() == y))
switch(playerFacingDirection)
case 0: c = '>'; break;
case 1: c = 'V'; break;
case 2: c = '<'; break;
case 3: c = '^'; break;
System.out.print(c);
System.out.println();
// For unit test debugging
void setPosition(final Coordinates coordinates, final int direction)
playerCoordinates = coordinates.clone();
playerFacingDirection = direction;
dumpWithPlayer();
And the updated driver:
final class Day22
/* a sample square side numbering:
| 3 |
|2 A 0|
| 1 |
static final String[] FLAT_LAYOUT4 =
A
BCD
EF
""".split("\n");
static final String[] MOVEMENT_RULES4 =
A0F0
A1D3
A2C3
A3B3
B0C2
B1E1
B2F1
B3A3
C0D2
C1E2
C2B0
C3A2
D0F3
D1E3
D2C0
D3A1
E0F2
E1B1
E2C1
E3D1
F0A0
F1B2
F2E0
F3D0
""".split("\n");
public static long part2(final String[] day22InputLines, final String movementInstructions, final int width, final int height, final int cubeSize)
final CubeMovementRules cmr;
if (cubeSize == 4)
// Sample input
cmr = new CubeMovementRules(cubeSize);
cmr.defineFlatLayout(FLAT_LAYOUT4);
cmr.addRules(MOVEMENT_RULES4);
else if (cubeSize == 50)
// Day input
cmr.defineFlatLayout(AdventOfCode2022Day22Main.FLAT_LAYOUT50);
cmr.addRules(AdventOfCode2022Day22Main.MOVEMENT_RULES50);
else
cmr = CubeMovementRules.INVALID_CUBE_MOVEMENT_RULES;
final MonkeyGrove2 mg = new MonkeyGrove2(width, height, cmr);
return mg.getPart2Answer();
I included the necessary FLAT_LAYOUT50 and MOVEMENT_RULES50 in my main because they were specific to my input, but they looked very similar to the ones in the driver for the example.
