https://github.com/mainmeister/urlsum
urlsum
AI-driven 450-character hard limit summary of the contents of a URL.
Features
- Summarizes webpages into a single, concise paragraph.
- Enforces a strict 450-character limit with complete sentences.
- Supports Google Gemini API (default).
- Supports local Ollama models.
- Automatically copies the summary to the clipboard (supports Wayland and X11).
- Can output scraped text in a clean human-readable form.
Installation
Prerequisites
- Python 3.x
requestscrawlee[beautifulsoup]- (Optional)
wl-copy,xclip, orxselfor clipboard support.
Setup
Clone the repository:
git clone https://github.com/mainmeister/urlsum.git cd urlsum -
Install dependencies:
pip install requests "crawlee[beautifulsoup]" -
(Optional) Make the script executable and add it to your PATH.
Usage
usage: urlsum [-h] [--set-key SET_KEY] [-d] [-m MODEL] [-o [OLLAMA]] [-t TIMEOUT] [-v] [--no-clipboard] [url]
positional arguments:
url The URL of the webpage to summarize.
options:
-h, --help show this help message and exit
--set-key SET_KEY Save your Gemini API key to the config file.
-d, --default Set the default Ollama model.
-m MODEL, --model MODEL
Gemini model to use (default: gemini-2.5-flash).
-o [OLLAMA], --ollama [OLLAMA]
Use local Ollama service instead of Gemini. Optional: model name (default: llama3).
-t TIMEOUT, --timeout TIMEOUT
Timeout for Ollama service (e.g., 300 or 5:00). Default: 600s.
-v, --verbose Output the scraped text in a clean human-readable form.
--no-clipboard Do not copy the summary to the clipboard.
Examples
Using Gemini (Default)
First, set your API key:
urlsum --set-key YOUR_GEMINI_API_KEY
Summarize a URL:
urlsum https://example.com
Using Ollama
Set a default Ollama model:
urlsum -d
Summarize using Ollama:
urlsum -o https://example.com
Specify a different model for a single run:
urlsum -o llama3.2 https://example.com
Configuration
Settings are stored in ~/.config/urlsum/config.json.
License
MIT
