WW 759: Local Hooch
What happens long term to Windows 10 users who do not get updated to Windows 11? Will support end at some point?
Windows 10 is supported through 2025.
Windows 10 came out in 2015, and will be supported for 10 years. This is similar to what it did for all versions of Windows prior. (Traditionally it was 5 years of full support and 5 more of extended support, which means bugfix only and no feature changes.) If you want to stay on Windows 10 and you’re extra lucky, Microsoft may extend the 10 years a bit, as it did with XP, but I wouldn’t count on that.
Boy, I just noticed I can edit the title of, e.g., this thread (remove an additional w) based on acquired forum status. It feels like a superpower. Must. Only. Use. For. Good.
With great power comes great responsibility!
@PHolder has been pretty much been holding down the fort for the past year. Any help would be more than appreciated!!
I have this power as well, but not sure if I’ve ever used it. Trying to be very respectful of my fellow netizens here.
