There’s a correction that needs to be made about turning off Face ID till you enter your pin. On the show you said you just have to hold the lock button for two seconds but you forgot to include you also have to press at the same time either volume button; doesn’t matter which up or down but you must press the lock button “and” a volume button for two seconds.
Love your show and love you Leo! Your a great guy!
Take care!
SJA
Yeah the method varies depending on your phone and OS. The best advice is to check online about how to lock your specific model then memorize it!
@Leo you mentioned that TV anchors use hollow tube earphones. Is there a reason for this? Are they better quality than a wire connection? Thanks.
Just a wild ass guess: I’m going to guess that the reason is that there is thus no electronics in the earpiece, making is far less likely the earpiece will break and additionally they can more easily be replaced for different anchors at a lower cost. If they are customized to the anchor, they can take them with them to the next job/show whereas the receiver/amplifier portion might be tied to the production they were on previously. (The thinking being that those are potentially on licensed frequencies specific to the production.)
