I want to add a stand alone router to the router my isp provides. Is this a good choice?
TP-Link Archer AX55 (AX3000)
TPLink is on the US banned list because they’ve been repeatedly attacked and taken over by bad actors. Now I am not suggesting you trust the US government’s silly perspective on kicking companies out of the US unless they pay what amounts to a bribe, but I also think TP Link may really have a security problem with their firmware.
If I were you, I would consider the Flint 2 or 3 (or 4 if you’re fancy) from GLinet. It runs a reskinned open source router firmware, and they seem to do a good job keeping it up to date.
One thing you should find out, is if you can change the configuration of your ISP router (or if you can have it changed for you) to disable its firewall, and put it into “bridge mode” so you don’t end up double NAT’ed. (I was able to do that with my ISP modem/router combination.)
