These look ok but it depends on your network settings, are you getting an error after this ?
You could set it to not to use a static IP (it might say dynamic or DHCP) which would get you past this screen. If you need a static IP you can always change that later.
I cannot believe this. I had the very same issue with my Pi 3 the other day. I was installing Raspbian and it wouldn’t get a DHCP lease, only stateless IPv6 would work. Then I tried to install Xbian, same thing. Resetting my router did the trick.
