I am looking for a way to rip DVDs directly to an iPad Air 3. Without using a computer
Even if an external DVD player could be hooked up with the USB Camera Connection Kit, I don’t think the software exists in the app store to rip DVDs.
My suggestion is not what you want but what you want is very niche I suspect. Instead you could probably set up some sort of remote control situation using a Mac (or a PC)… but I suspect you really want a server to host the content and stream it to your iPad anyway. I would get the movies onto a Mac/PC/NAS running a Plex server.
Looks like Handbrake has an ipad app.
https://www.imelfin.com/best-handbrake-setting-for-ipad.html
Sadly that’s just the best settings to watch the resulting file on your iPad.
There is no way to rip a DVD on iPad.
